[mapguide][MG92][Modified] Base layer group doesn't display if name contains a ")"
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Mar 10 17:00:22 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG92
Type:
Defect
Artifact ID:
MG92 (Base layer group doesn't display if name contains a ")")
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Steps to Reproduce set to new value:
Old value:
Create a map containing a base layer group that has the ")" character in it, and preview the map.
The tiles for the base layer group will not display.
New value:
- create a map containing a base layer group that has the ")" character in it, and preview the map
- the tiles for the base layer group will not display
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
