[mapguide][MG93][New] Server Error in '/mapguide/mapviewerajax' Application. Compi...
    Ron Greenhalgh
    rgreenhalgh at mscon.com
    Fri Mar 10 17:36:47 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG93
Type
 Defect
Artifact ID
 MG93 (Server Error in '/mapguide/mapviewerajax' Application. Compilation Error)
Reported by
 Ron Greenhalgh
 rgreenhalgh (rgreenhalgh at mscon.com)
New artifact details:
- Artifact Status set to new value
  New
- Subcomponent set to new value
  AJAX Viewer
- Steps to Reproduce set to new value
  I get the error in the MapGuide Studio as well. We have loaded it on another machine here and it works there. I do have the .NET Framwork 2.0 and the other machine doesn't.
- Version set to new value
  1.0.0
- Artifact created
- Summary set to new value
- Platform set to new value
  PC
- Operating system set to new value
  Windows XP
- Defect Severity set to new value
  High
- Component set to new value
  Web Server Extensions
- Description set to new value
  I get the following error when I goto:
http://localhost/mapguide/mapviewerajax/ajaxviewer.aspx?
Compilation Error
Description: An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately.
Compiler Error Message: CS0246: The type or namespace name 'OSGeo' could not be found (are you missing a using directive or an assembly reference?)
Source Error:
Line 19: <%@ Import Namespace="System.Collections.Specialized" %>
Line 20: <%@ Import Namespace="System.IO" %>
Line 21: <%@ Import Namespace="OSGeo.MapGuide" %>
Line 22:
Line 23: <script runat="server">int forDwf=0;</script>
Source File: C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\ajaxviewer.aspx    Line: 21
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
