[mapguide][MG94][New] DWF Viewer not opening feature URL link in NEW WINDOW when s...
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Mar 10 17:43:02 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG94
Type
Defect
Artifact ID
MG94 (DWF Viewer not opening feature URL link in NEW WINDOW when set to NEW WINDOW in web layout)
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Subcomponent set to new value
DWF Viewer
- Component set to new value
Web Server Extensions
- Platform set to new value
PC
- Artifact Status set to new value
New
- Description set to new value
See the summary - it says it all.
- Steps to Reproduce set to new value
1/ create a layer with any kind of data
2/ under the "URL activated for feature" field set a constant URL like "http://www.cnn.com" (this is in Studio)
3/ add the layer to a map
4/ create a web layout for the map
5/ set the "Open feature URL hyperlinks in this target interface" to "New Window"
6/ Open the web layout with the DWF Viewer embedded
7/ Ctrl-click on a feature
=> the link open in the same window as the web layout
- Operating system set to new value
Windows XP
- Artifact created
- Summary set to new value
- Version set to new value
1.0.0
- Priority set to new value
P3
- Defect Severity set to new value
Medium
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
