[mapguide][MG97][Modified] Base layer has wrong initial visibility in EMap
Walt Welton-Lair
walt.welton-lair at autodesk.com
Sat Mar 11 03:27:41 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG97
Type:
Defect
Artifact ID:
MG97 (Base layer has wrong initial visibility in EMap)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
See steps to reproduce.
New value:
Note that the problem also occurs with regular layers and layer groups. These don't always have the correct initial visibility value.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
