[mapguide][MG98][New] Geometry unit tests failed on Linux
Steve Dang
steve.dang at autodesk.com
Sat Mar 11 13:04:23 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG98
Type
Defect
Artifact ID
MG98 (Geometry unit tests failed on Linux)
Reported by
Steve Dang
stevedang (steve.dang at autodesk.com)
New artifact details:
- Description set to new value
This artifact fixes the two Geometry unit test failures on Linux. They are the Convex Hull test cases. It only happens to the release Server on Linux.
Slightly different results with rounding under debug and release builds apply to Windows only. The Geometry unit tests have been modified to check for the same results under debug and release builds for Linux.
- Component set to new value
Server
- Operating system set to new value
Linux
- Subcomponent set to new value
General
- Steps to Reproduce set to new value
1. Build the release Server.
2. Run the Geometry unit tests.
3. Notice that the test result (failed/run) is 1/32. There were actually two failures but only one was shown up because the unit tests skiped to the next test case after catching the first exception from the current test case.
- Version set to new value
1.0.0
- Artifact Status set to new value
New
- Summary set to new value
- Priority set to new value
P3
- Artifact created
- Defect Severity set to new value
Medium
- Platform set to new value
PC
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
