[mapguide][MG111][Modified] Scale ranges parsed incorrectly for grid and drawing layers ...
Traian Stanev traian.stanev at autodesk.com
Wed Mar 15 16:26:48 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG111
Type:
Defect
Artifact ID:
MG111 (Scale ranges parsed incorrectly for grid and drawing layers in MgLayer)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
MG111 : Scale ranges are not parsed and initialized correctly for Drawing and Grid MDF layers. Handling for GridLayers was missing while scales were not initialized for DrawingLayers resulting in erratic behavior in the case where the layer uses defaults (i.e. not explicitly set in the layer definition XML).
Modified
File: trunk/MgDev/Common/Service/MapLayer/Layer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/MapLayer/Layer.cpp?view=diff&rev=314&p1=trunk/MgDev/Common/Service/MapLayer/Layer.cpp&r1=313&p2=trunk/MgDev/Common/Service/MapLayer/Layer.cpp&r2=314
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
