[mapguide][MG111][Modified] Scale ranges parsed incorrectly for grid and drawing layers ...
Traian Stanev
traian.stanev at autodesk.com
Wed Mar 15 16:29:57 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG111
Type:
Defect
Artifact ID:
MG111 (Scale ranges parsed incorrectly for grid and drawing layers in MgLayer)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Added code to handle grid layers and initialized default scales for drawing layers. The code in MgLayer needs to be updated to use the MDF parser to parse the XML instead of doing manual DOM parsing -- this way it would not fall out of date so easily.
-- Submission Reviewed set to new value:
Yes
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
