[mapguide][MG133][Modified] Web layouts containing JPN characters do not display correct...
Walt Welton-Lair walt.welton-lair at autodesk.com
Fri Mar 17 13:46:35 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG133
Type:
Defect
Artifact ID:
MG133 (Web layouts containing JPN characters do not display correctly in JPN OS)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Steps to Reproduce set to new value:
Old value:
See description.
New value:
See description.
Note that the problem does not show up if you're running an English OS.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
