[mapguide][MG134][New] Measure command does not work with non Lat/Lon coordinate sy...
Alain Lebatard
alain.lebatard at autodesk.com
Fri Mar 17 13:54:32 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG134
Type
Defect
Artifact ID
MG134 (Measure command does not work with non Lat/Lon coordinate systems)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Version set to new value
1.0.0
- Summary set to new value
- Platform set to new value
All
- Artifact created
- Steps to Reproduce set to new value
Create a map with a layer from redding data, say Hospitals.
Open a web layout linked to this map
Execute a measure command and calculate distance between 2 hospital features.
=> No red segment appears. Distance is wrong.
- Description set to new value
The measure command has 2 problems when working with a non lat/lon coordinate system:
- Calculated distance is incorrect
- Red Segment features do not appear on the map although the measure layer is correctly created and appears in the legend control
- Artifact Status set to new value
New
- Subcomponent set to new value
Viewer Command
- Defect Severity set to new value
High
- Component set to new value
Web Server Extensions
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
