[mapguide][MG95][Modified] MakePackage API implementation.
Steve Dang
steve.dang at autodesk.com
Fri Mar 17 16:31:43 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG95
Type:
Enhancement
Artifact ID:
MG95 (MakePackage API implementation.)
Modified by:
Steve Dang
stevedang (steve.dang at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
Update to convert the server IP address to the host name so that it can be included in the status message.
Windows Server unit tests failed/run: 0/378
Linux Server unit tests failed/run: 0/378
Windows Web Tier unit tests failed/run: 0/921
Modified
File: trunk/MgDev/Common/Service/Services/PackageStatusInformation.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Services/PackageStatusInformation.cpp?view=diff&rev=345&p1=trunk/MgDev/Common/Service/Services/PackageStatusInformation.cpp&r1=344&p2=trunk/MgDev/Common/Service/Services/PackageStatusInformation.cpp&r2=345
File: trunk/MgDev/Common/Service/Services/PackageStatusInformation.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Services/PackageStatusInformation.h?view=diff&rev=345&p1=trunk/MgDev/Common/Service/Services/PackageStatusInformation.h&r1=344&p2=trunk/MgDev/Common/Service/Services/PackageStatusInformation.h&r2=345
File: trunk/MgDev/Server/src/Common/Manager/PackageLogHandler.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Common/Manager/PackageLogHandler.cpp?view=diff&rev=345&p1=trunk/MgDev/Server/src/Common/Manager/PackageLogHandler.cpp&r1=344&p2=trunk/MgDev/Server/src/Common/Manager/PackageLogHandler.cpp&r2=345
File: trunk/MgDev/Server/src/Common/Manager/PackageLogHandler.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Common/Manager/PackageLogHandler.h?view=diff&rev=345&p1=trunk/MgDev/Server/src/Common/Manager/PackageLogHandler.h&r1=344&p2=trunk/MgDev/Server/src/Common/Manager/PackageLogHandler.h&r2=345
File: trunk/MgDev/Server/src/Common/Manager/PackageLogReader.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Common/Manager/PackageLogReader.cpp?view=diff&rev=345&p1=trunk/MgDev/Server/src/Common/Manager/PackageLogReader.cpp&r1=344&p2=trunk/MgDev/Server/src/Common/Manager/PackageLogReader.cpp&r2=345
File: trunk/MgDev/Server/src/Common/Manager/PackageLogWriter.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Common/Manager/PackageLogWriter.cpp?view=diff&rev=345&p1=trunk/MgDev/Server/src/Common/Manager/PackageLogWriter.cpp&r1=344&p2=trunk/MgDev/Server/src/Common/Manager/PackageLogWriter.cpp&r2=345
File: trunk/MgDev/Server/src/Services/Resource/ResourcePackageHandler.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourcePackageHandler.cpp?view=diff&rev=345&p1=trunk/MgDev/Server/src/Services/Resource/ResourcePackageHandler.cpp&r1=344&p2=trunk/MgDev/Server/src/Services/Resource/ResourcePackageHandler.cpp&r2=345
File: trunk/MgDev/Server/src/Services/Resource/ResourcePackageMaker.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourcePackageMaker.cpp?view=diff&rev=345&p1=trunk/MgDev/Server/src/Services/Resource/ResourcePackageMaker.cpp&r1=344&p2=trunk/MgDev/Server/src/Services/Resource/ResourcePackageMaker.cpp&r2=345
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
