[mapguide][MG135][New] Problems with log file names and archiving
Ronnie Louie
ronnie.louie at autodesk.com
Fri Mar 17 19:18:09 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG135
Type
Defect
Artifact ID
MG135 (Problems with log file names and archiving)
Reported by
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Artifact created
- Steps to Reproduce set to new value
1. Invoke Site Admin and go to the Configure Logs page.
2. Select the Trace tab and check the name specified for the file. This file should be currently residing in the server's Logs folder. 3. Modify the set of parameters for the Trace log and hit Save.
4. Hit another tab on the Configure Logs page - this will cause some entries to be written to the active Trace log.
5. Check the server's Logs folder. The Trace log should have been archived and a new file opened when the parameter set was modified. This is not the case. The same active file is in use. The most recent entries use the new paramenter configuration.
6. Also notice that the filename is suffixed with a two-digit suffix, corresponding to the the current date depending on the archive frequency specifier (day, month, or year).
- Subcomponent set to new value
General
- Priority set to new value
P3
- Version set to new value
1.0.0
- Platform set to new value
All
- Operating system set to new value
All
- Description set to new value
Server logs should be archived when the logging paramters have changed so the the log metadata is in sync with the log contents. The archived log file names should be suffixed with the time of the archive. Archives should also be created based on the archive frequency specifier. The intended behaviour is currently not the actual behaviour. The active log have the wrong name, and the active logs are showing up in the archive logs tab of the Manage Logs page.
- Summary set to new value
- Defect Severity set to new value
Medium
- Component set to new value
Server
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
