[mapguide][MG133][Modified] Web layouts containing JPN characters do not display correct...
Walt Welton-Lair walt.welton-lair at autodesk.com
Sat Mar 18 01:49:08 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG133
Type:
Defect
Artifact ID:
MG133 (Web layouts containing JPN characters do not display correctly in JPN OS)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Resolution set to new value:
Submitted
-- Status Explanation set to new value:
Code fix has been submitted.
-- Resolution Description set to new value:
-- Testing Notes set to new value:
- tested fixes with both DWF and AJAX viewers
- tested fixes with PHP, JSP, and ASPX
- tested fixes using both IE and Firefox
- tested fixes under both JPN and english OS'es
- tested following cases:
  * web layout name contain JPN characters
  * web layout in a folder whose name contains JPN characters
  * web layout which references a map definition that contains JPN characters
  * web layout which has a title which contains JPN characters
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
