[mapguide][MG133][Modified] Web layouts containing JPN characters do not display correct...
Walt Welton-Lair walt.welton-lair at autodesk.com
Sat Mar 18 01:59:03 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG133
Type:
Defect
Artifact ID:
MG133 (Web layouts containing JPN characters do not display correctly in JPN OS)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Developer Notes set to new value:
Old value:
The problem is that the web surround makes numerous server requests which include the web layout resource ID as a parameter, and this ID is not getting url-encoded in all places.
New value:
Also found places where a map definition resource ID was not getting encoded.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
