[mapguide][MG134][Modified] Measure command does not work with non Lat/Lon coordinate sy...
Alain Lebatard alain.lebatard at autodesk.com
Sun Mar 19 20:13:40 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG134
Type:
Defect
Artifact ID:
MG134 (Measure command does not work with non Lat/Lon coordinate systems)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Target milestone set to new value:
1.0.1
-- Resolution Description set to new value:
This submission fixes a few things that the measure commands was doing wrong, mainly:
  - distance segment features were created in Lat/Lon instead of the map coordinate system
  - distance calculation didn't distinguish the type of coordinate system, leading to wrong results. Now the calculation uses a great circle mehod for geographic coordinate systems, and an euclidian method otherwise
-- Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
