[mapguide][MG136][New] Web Extensions do not load coordinate system categories
Trevor Wekel trevor.wekel at autodesk.com
Sun Mar 19 21:08:07 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG136
Type
 Defect
Artifact ID
 MG136 (Web Extensions do not load coordinate system categories)
Reported by
 Trevor Wekel
 trevorwekel (trevor.wekel at autodesk.com)
New artifact details:
- Added file attachment
  testcoord.php
- Status Explanation set to new value
  Coordinate system categories will not function in the Web Extensions API.
- Summary set to new value
- Steps to Reproduce set to new value
  Run the attached PHP script.  Only arbitrary XY is displayed if the categories are not loaded.
- Artifact created
- Submission Reviewed set to new value
  No
- Operating system set to new value
  All
- Platform set to new value
  All
- Defect Severity set to new value
  Medium
- Version set to new value
  1.0.0
- Description set to new value
  The Web Extensions do not load the PROJ4 coordinate system categories files.  Although this is not a showstopper defect, it will have CoordSys API implications.
Note:  Additional installer work is required to install categories.txt into the www/nad directory on Windows and the share/proj directory on Linux.
- Target milestone set to new value
  1.0.1
- Artifact Status set to new value
  New
- Subcomponent set to new value
  Web API
- Priority set to new value
  P2
- Component set to new value
  Web Server Extensions
- Integration and Build Notes set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
