[mapguide][MG147][New] Create method to convert geometry from polygon to line
Jason Birch jason.birch at nanaimo.ca
Tue Mar 21 11:40:34 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG147
Type
 Enhancement
Artifact ID
 MG147 (Create method to convert geometry from polygon to line)
Reported by
 Jason Birch
 jasonbirch (jason.birch at nanaimo.ca)
New artifact details:
- Description set to new value
  Please create a method that returns a linear representation of geometries with polygon or multipolygon geometry type.  Alternately, add a parameter to the feature query that allows degrading the results to either points or lines.
- Summary set to new value
- Justification set to new value
  Goals:
 - store data once
 - return data in most efficient format
In my case, I want to be able to use a polygonal layer (with shading) in the viewer, while returning a line when displaying via the API for Google Earth.  I can hack this with a regular expression string replace on the WKT text but it would be much more convenient and efficient if this was provided out of the box.
- Artifact Status set to new value
  New
- Artifact created
Reason:
Initial request
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
