[mapguide][MG130][Modified] Expression for label rotation not getting saved to XML
Ben Trumbore ben.trumbore at autodesk.com
Tue Mar 21 11:41:42 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG130
Type:
Defect
Artifact ID:
MG130 (Expression for label rotation not getting saved to XML)
Modified by:
Ben Trumbore
bentrumbore (ben.trumbore at autodesk.com)
The following modifications were made to this artifact:
-- Status Explanation set to new value:
Old value:
Code fix has been submitted.
New value:
*** It was discovered that this change caused the default rotation of "0" to be written out, where before it was omitted.  This broke some unit tests, so the code is being changed again.
-- Artifact Status changed:
Old value:
Resolved
New value:
Reopened
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
