[mapguide][MG144][Modified] MgColor is not part of the third-party API
Alain Lebatard
alain.lebatard at autodesk.com
Tue Mar 21 13:34:00 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG144
Type:
Defect
Artifact ID:
MG144 (MgColor is not part of the third-party API)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Resolution set to new value:
Submitted
-- Testing Notes set to new value:
Tests failed/run: 2/921
2 unrelated failures in SelectFeatures unit test.
-- Target milestone set to new value:
1.0.1
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution Description set to new value:
The class MgColor was not declared in SWIG's interface file
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
