[mapguide][MG158][Modified] Please allow specification of lines and polygon borders in m...
Tom Fukushima
tom.fukushima at autodesk.com
Thu Mar 23 13:31:08 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG158
Type:
Enhancement
Artifact ID:
MG158 (Please allow specification of lines and polygon borders in map units/mapping space)
Modified by:
Tom Fukushima
tomfukushima (tom.fukushima at autodesk.com)
The following modifications were made to this artifact:
-- Justification set to new value:
Old value:
Two examples:
- At large scales, I want road centrelines to show up at the their physical width, as defined in the database. I don't have a polygonal roads coverage; this allows me to shade the roads.
- I want to be able to do the same with utility pipes to show their physical width.
I can work around this by pre-processing the lines into polygons (using FME), but it would be much nicer if I could just define a map-units line width in the application.
New value:
Two examples:
>From Kevin Mayall:
I've been wanting this in MG for some time.
Another example: say I have a polygon layer (parcels, zoning, habitats) and the boundary of the polygon should be interpreted as imprecise - say, the actual line could be within 10 feet on either side. I would want this line to have a 20-foot width, that is defined in ground/map units.
This avoids the common issue of having users attribute false precision to boundary locations as they zoom in. It's a big issue in map use.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
