[mapguide][MG159][New] Add Oracle client check to prevent Oracle FDO G001 provider ...
Bruce Dechant
bruce.dechant at autodesk.com
Thu Mar 23 15:33:06 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG159
Type
Defect
Artifact ID
MG159 (Add Oracle client check to prevent Oracle FDO G001 provider crashing)
Reported by
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Priority set to new value
P2
- Subcomponent set to new value
Feature Service
- Operating system set to new value
All
- Component set to new value
Server
- Steps to Reproduce set to new value
Try and create an Oracle connection on a machine that has no Oracle client. The MapGuide server will crash.
You can simulate no Oracle client be renaming your Oracle client folder before running the server.
- Artifact created
- Platform set to new value
All
- Summary set to new value
- Artifact Status set to new value
New
- Version set to new value
1.0.0
- Description set to new value
Add Oracle client check to workaround Oracle FDO G001 provider crashing the server when no Oracle client is installed.
This workaround will be removed in a future submission once the regression bug inside the Oracle FDO G001 provider has been fixed.
- Defect Severity set to new value
High
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
