[mapguide][MG125][User] Change layer template used in code samples for Dev Guide.
Walt Welton-Lair
walt.welton-lair at autodesk.com
Mon Mar 27 13:00:54 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG125
Type:
Defect
Artifact ID:
MG125 (Change layer template used in code samples for Dev Guide.)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- New value added to attribute Assigned to:
philipsharman
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
