[mapguide][MG125][Modified] Change layer template used in code samples for Dev Guide.
Walt Welton-Lair walt.welton-lair at autodesk.com
Mon Mar 27 13:01:12 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG125
Type:
Defect
Artifact ID:
MG125 (Change layer template used in code samples for Dev Guide.)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Target milestone set to new value:
1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
