[mapguide][MG270][Modified] Nothing draws if point symbol is missing from the library
Traian Stanev traian.stanev at autodesk.com
Wed May 3 08:41:51 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG270
Type:
Defect
Artifact ID:
MG270 (Nothing draws if point symbol is missing from the library)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
Added a new symbol definition which will be used as a placeholder for missing symbols or symbol libraries. It is essentially a red square with a red X inside it.
Modified
File: trunk/MgDev/Common/Stylization/DWFRenderer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/DWFRenderer.cpp?view=diff&rev=600&p1=trunk/MgDev/Common/Stylization/DWFRenderer.cpp&r1=599&p2=trunk/MgDev/Common/Stylization/DWFRenderer.cpp&r2=600
File: trunk/MgDev/Common/Stylization/GDRenderer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/GDRenderer.cpp?view=diff&rev=600&p1=trunk/MgDev/Common/Stylization/GDRenderer.cpp&r1=599&p2=trunk/MgDev/Common/Stylization/GDRenderer.cpp&r2=600
File: trunk/MgDev/Common/Stylization/SLDSymbols.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/SLDSymbols.h?view=diff&rev=600&p1=trunk/MgDev/Common/Stylization/SLDSymbols.h&r1=599&p2=trunk/MgDev/Common/Stylization/SLDSymbols.h&r2=600
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
