[mapguide][MG270][Modified] Nothing draws if point symbol is missing from the library
Traian Stanev
traian.stanev at autodesk.com
Wed May 3 08:43:39 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG270
Type:
Defect
Artifact ID:
MG270 (Nothing draws if point symbol is missing from the library)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- Status Explanation set to new value:
x.
-- Resolution Description set to new value:
Added a new symbol definition which will be used as a placeholder for missing symbols or symbol libraries. It is essentially a red square with a red X inside it.
-- Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Submission Reviewed set to new value:
No
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
