[mapguide][MG274][New] Thru an exception when using CANST-NB83-CSRS Coordinate syst...
Pascal Landry
pascal.landry at gnb.ca
Wed May 3 15:29:56 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG274
Type
Defect
Artifact ID
MG274 (Thru an exception when using CANST-NB83-CSRS Coordinate system)
Reported by
Pascal Landry
scal (pascal.landry at gnb.ca)
New artifact details:
- OS Distribution and Version set to new value
Windows 2003 server
- Artifact Status set to new value
New
- Summary set to new value
- Defect Severity set to new value
High
- Artifact created
- Version set to new value
1.0.0
- Operating system set to new value
Windows 2000
- Description set to new value
The coordinate system is invalid. PROJCS["CANST-NB83-CSRS",GEOGCS["CANST-NB83-CSRS",DATUM["CSRS",SPHEROID["GRS 80",6378137,298.25722210089],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["Degrees", 0.0174532925199433]],PROJECTION["OSTERO"],PARAMETER["central_meridian", -66.5],PARAMETER["latitude_of_origin", 46.5],PARAMETER["scale_factor", 0.999912],PARAMETER["false_easting", 2500000],PARAMETER["false_northing", 7500000],UNIT["METER", 1]] Could not create coordinate system forward transformation with specified coordinate systems.
The coordinate system is invalid. PROJCS["CANST-NB83-CSRS",GEOGCS["CANST-NB83-CSRS",DATUM["CSRS",SPHEROID["GRS 80",6378137,298.25722210089],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["Degrees", 0.0174532925199433]],PROJECTION["OSTERO"],PARAMETER["central_meridian", -66.5],PARAMETER["latitude_of_origin", 46.5],PARAMETER["scale_factor", 0.999912],PARAMETER["false_easting", 2500000],PARAMETER["false_northing", 7500000],UNIT["METER", 1]] Could not create coordinate system forward transformation with specified coordinate systems. Exception occurred in method MgCoordinateSystem.MgCoordinateSystem at line 76 in file c:\build_tux_area\mgdev\common\service\coordinatesystem\CoordinateSystem.cpp
- Steps to Reproduce set to new value
Can send ESRI shape file to reproduce.
- Platform set to new value
PC
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
