[mapguide][MG275][New] Remove version from provider name.
Bruce Dechant bruce.dechant at autodesk.com
Wed May 3 17:16:04 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG275
Type
 Task
Artifact ID
 MG275 (Remove version from provider name.)
Reported by
 Bruce Dechant
 brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Summary set to new value
- Artifact Status set to new value
  New
- Priority set to new value
  P2
- Task Priority set to new value
  Medium
- Description set to new value
  The next drop of FDO will no longer require the version to be part of the provider name. If a version is not specified the latest version will be used.
This will allow FDO to update to new API versions without breaking existing feature sources.
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
