[mapguide][MG277][Modified] Fix Feature Service unit test broken as a result of update F...
Ronnie Louie ronnie.louie at autodesk.com
Thu May 4 12:28:59 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG277
Type:
Defect
Artifact ID:
MG277 (Fix Feature Service unit test broken as a result of update FDO update)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Plug memory leak introduced when using MgFdoConnectionManager::UpdateProviderName().  Cannot pass a string to this method and then return it into the same string.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
