[mapguide][MG278][New] Fix broken Web tier unit tests due to FDO update
Ronnie Louie
ronnie.louie at autodesk.com
Thu May 4 16:42:27 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG278
Type
Defect
Artifact ID
MG278 (Fix broken Web tier unit tests due to FDO update)
Reported by
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
New artifact details:
- Steps to Reproduce set to new value
Run web tier unit tests.
- Build set to new value
173.4
- Testing Notes set to new value
Webtier unit tests: 0/934 tests failed
- Defect Severity set to new value
High
- Target milestone set to new value
1.0.1
- Artifact Status set to new value
New
- Description set to new value
Broken web tier unit tests as a result of FDO update.
- Related Artifacts set to new value
MG277, MG275
- Summary set to new value
- Version set to new value
1.0.0
- Priority set to new value
P2
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
