[mapguide][MG283][Modified] Update MapAdmin to control legend font server configuration ...
    Walt Welton-Lair
    walt.welton-lair at autodesk.com
    Tue May  9 15:30:26 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG283
Type:
Enhancement
Artifact ID:
MG283 (Update MapAdmin to control legend font server configuration setting)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
The server now has a legend font configuration setting - this is for Mapping Services.  The setting controls the font that's used by the server when generating legend images.
The MapAdmin tool should be updated to allow an administrator to change this setting.  Currently the serverconfig.ini file has to be modified by hand.
New value:
The server now has a legend font configuration setting - this is for Mapping Services (see artifact MG282).  The setting controls the font that's used by the server when generating legend images.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
