[mapguide][MG282][Modified] Fix globalization issue with print view page in AJAX Viewer
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue May 9 17:50:08 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG282
Type:
Defect
Artifact ID:
MG282 (Fix globalization issue with print view page in AJAX Viewer)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Developer Notes set to new value:
Old value:
The fix for this will be to add a server configuration setting which specifies which font to use for the legend preview.  This is not much different than labels, in which the user also has to specify which font to use.  The only difference is that this is a global setting and not a per-layer setting.
New value:
For Windows the legend font is set to Arial.  For Linux, I've updated Makefile.am to replace this with Complex (one of the fonts we include with Linux).
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
