[mapguide][MG283][Modified] Update MapAdmin to control legend font server configuration ...
Louise Watson
louise.watson at autodesk.com
Wed May 10 09:17:36 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG283
Type:
Enhancement
Artifact ID:
MG283 (Update MapAdmin to control legend font server configuration setting)
Modified by:
Louise Watson
louisewatson (louise.watson at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Old value:
Adding this feature to the Site Admin UI is fairly simple. First, because until now there have not been any Mapping Service properties presented in the UI, handling for that service must be added to ServicesProperties, ServerDataFunctions, and ResizablePageComponents files. The Mapping Service, of course, would present the new font property.
Be aware that this change would affect the corresponding help page as this page gives a description of each property presented on the page.
New value:
Adding this feature to the Site Admin UI is fairly simple. First, because until now there have not been any Mapping Service properties presented in the UI, handling for that service must be added to ServicesProperties, ServerDataFunctions, and ResizablePageComponents files. The Mapping Service, of course, would present the new font property. Here we need to decide if a simple text box is adequate for specifying the font or if we need a drop-down list presenting all possible fonts.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
