[mapguide][MG284][New] DescribeDrawing does not generate a valid XML file in some c...
Ronnie Louie ronnie.louie at autodesk.com
Wed May 10 13:50:01 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG284
Type
 Defect
Artifact ID
 MG284 (DescribeDrawing does not generate a valid XML file in some cases)
Reported by
 Ronnie Louie
 ronnielouie (ronnie.louie at autodesk.com)
New artifact details:
- Build set to new value
  174.5
- Steps to Reproduce set to new value
  1) Upload the attached DWF resource to the repository
2) Using the PHP pages execute a DescribeDrawing for the uploaded DWF
An error is generated " Invalid at the top level of the document. Error processing resource 'http://localhost/PhpMapAgent/MapAgent.php?OPERATION=DE..."
The same result occurs using the API and writing the output to a file.
- Target milestone set to new value
  1.0.1
- Added file attachment
  Sample_World_SDF.dwf
- Defect Severity set to new value
  High
- External ID set to new value
  696157
- Component set to new value
  Server
- Description set to new value
  MgDrawingService::DescribeDrawing() operation should retrieve the DWF manifest in XML format.  For some DWFs, the result is an invalid XML document due to some extra characters at the end of the document.
- Subcomponent set to new value
  Drawing Service
- Artifact created
- Artifact Status set to new value
  New
- Version set to new value
  1.0.0
- Summary set to new value
- Resolution Description set to new value
  Filter the retrieved manifest document for the extra characters which are causing the returned XML to be invalid.
- Priority set to new value
  P2
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
