[mapguide][MG286][New] Oracle FDO Provider causes the Server to crash on RH ES3 Lin...
    Vishal Bangia
    vishal.bangia at autodesk.com
    Thu May 11 19:23:27 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG286
Type
 Defect
Artifact ID
 MG286 (Oracle FDO Provider causes the Server to crash on RH ES3 Linux.)
Reported by
 Vishal Bangia
 vishalbangia (vishal.bangia at autodesk.com)
New artifact details:
- Steps to Reproduce set to new value
  Please refer to Defect 680879.
- Defect Severity set to new value
  High
- Subcomponent set to new value
  Feature Service
- Platform set to new value
  PC
- Priority set to new value
  P1
- Description set to new value
The problem arises as we have an assert in the server code base if an exception is thrown while accessing ReadNext() on the FeatureReader interface for FDO.
Technically, only the Oracle provider throws an exception if you access ReadNext() again after it return false and on Linux the assert causes the server to crash.
- Artifact created
- Resolution set to new value
  Submitted
- Submission Reviewed set to new value
  Yes
- OS Distribution and Version set to new value
  Red Hat ES 3.0
- Version set to new value
  1.0.0
- Summary set to new value
- Artifact Status set to new value
  New
- Resolution Description set to new value
  Removed the assert.
- Operating system set to new value
  Linux
- Component set to new value
  Server
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
