[mapguide][MG293][Modified] Exceptions logged by QueryFeatures (AJAX selection) in case ...
Traian Stanev
traian.stanev at autodesk.com
Fri May 19 10:11:40 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG293
Type:
Defect
Artifact ID:
MG293 (Exceptions logged by QueryFeatures (AJAX selection) in case of DWF layers)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- Resolution set to new value:
Submitted
-- Resolution Description set to new value:
We needed a check to make sure we are working with a vector layer and not a DWF layer, since the current selection scheme (spatial FDO query) only works for vector (FDO) layers. The check was already there, but it needed to be moved to contain the code that was causing the exception.
-- Status Explanation set to new value:
Fixed.
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Submission Reviewed set to new value:
No
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
