[mapguide][MG293][Modified] Exceptions logged by QueryFeatures (AJAX selection) in case ...
Traian Stanev traian.stanev at autodesk.com
Fri May 19 10:12:53 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG293
Type:
Defect
Artifact ID:
MG293 (Exceptions logged by QueryFeatures (AJAX selection) in case of DWF layers)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Old value:
We needed a check to make sure we are working with a vector layer and not a DWF layer, since the current selection scheme (spatial FDO query) only works for vector (FDO) layers. The check was already there, but it needed to be moved to contain the code that was causing the exception.
New value:
Also made a one line fix for point symbol selection -- the wrong type of square was drawing in the AJAX viewer to indicate selection of points.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
