[mapguide][MG294][New] Coord sys transform not performed from DWF-based layers
Traian Stanev
traian.stanev at autodesk.com
Fri May 19 15:39:43 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG294
Type
Defect
Artifact ID
MG294 (Coord sys transform not performed from DWF-based layers)
Reported by
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Target milestone set to new value
1.0.0
- Subcomponent set to new value
Mapping Service
- Description set to new value
Coordinate system reprojection was not working when a DWF layer uses a specified OGC coordinate system and the map itself uses a different coordinate system.
- Operating system set to new value
All
- Steps to Reproduce set to new value
Add a DWF layer and set its coord sys in the Studio load procedure to something other than arbitrary (something relevant to the DWF data). Make a map and add the layer to the map. Change the map coord sys to something other than the layer coord sys. Layer will not longer display, implying that reprojection is not working
- Platform set to new value
All
- Priority set to new value
P2
- Artifact created
- Summary set to new value
- Version set to new value
1.0.0
- Defect Severity set to new value
High
- Component set to new value
Server
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
