[mapguide][MG294][User] Coord sys transform not performed from DWF-based layers
Traian Stanev traian.stanev at autodesk.com
Fri May 19 15:40:01 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG294
Type:
Defect
Artifact ID:
MG294 (Coord sys transform not performed from DWF-based layers)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- New value added to attribute Reviewer:
waltweltonlair
-- New value added to attribute Assigned to:
traianstanev
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
