[mapguide][MG294][Modified] Coord sys transform not performed from DWF-based layers
Traian Stanev traian.stanev at autodesk.com
Fri May 19 15:40:42 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG294
Type:
Defect
Artifact ID:
MG294 (Coord sys transform not performed from DWF-based layers)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Assigned
-- Description set to new value:
Old value:
Coordinate system reprojection was not working when a DWF layer uses a specified OGC coordinate system and the map itself uses a different coordinate system.
New value:
-- Steps to Reproduce set to new value:
Old value:
Add a DWF layer and set its coord sys in the Studio load procedure to something other than arbitrary (something relevant to the DWF data). Make a map and add the layer to the map. Change the map coord sys to something other than the layer coord sys. Layer will not longer display, implying that reprojection is not working
New value:
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
