[mapguide][MG294][Modified] Coord sys transform not performed from DWF-based layers
Traian Stanev
traian.stanev at autodesk.com
Fri May 19 16:10:22 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG294
Type:
Defect
Artifact ID:
MG294 (Coord sys transform not performed from DWF-based layers)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
MG294: Coord sys transform not performed from DWF-based layers
Modified
File: trunk/MgDev/Common/Stylization/DefaultStylizer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/DefaultStylizer.cpp?view=diff&rev=664&p1=trunk/MgDev/Common/Stylization/DefaultStylizer.cpp&r1=663&p2=trunk/MgDev/Common/Stylization/DefaultStylizer.cpp&r2=664
File: trunk/MgDev/Common/Stylization/DefaultStylizer.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/DefaultStylizer.h?view=diff&rev=664&p1=trunk/MgDev/Common/Stylization/DefaultStylizer.h&r1=663&p2=trunk/MgDev/Common/Stylization/DefaultStylizer.h&r2=664
File: trunk/MgDev/Common/Stylization/Stylizer.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/Stylizer.h?view=diff&rev=664&p1=trunk/MgDev/Common/Stylization/Stylizer.h&r1=663&p2=trunk/MgDev/Common/Stylization/Stylizer.h&r2=664
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
