[mapguide][MG294][Modified] Coord sys transform not performed from DWF-based layers
Traian Stanev traian.stanev at autodesk.com
Fri May 19 16:12:55 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG294
Type:
Defect
Artifact ID:
MG294 (Coord sys transform not performed from DWF-based layers)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Resolution Description set to new value:
The code to do the coord sys transformation for DWF layers was there. The missing piece was that we were not passing down the coordinate system stored in the DWF drawing source resource content down to the stylization code. I added this piece and now it works.
-- Status Explanation set to new value:
Fixed.
-- Resolution set to new value:
Submitted
-- Submission Reviewed set to new value:
No
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
