[mapguide][MG295][New] InvokeURL doesn't work with specific layer constraint
Alain Lebatard
alain.lebatard at autodesk.com
Fri May 19 16:39:05 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG295
Type
Defect
Artifact ID
MG295 (InvokeURL doesn't work with specific layer constraint)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Description set to new value
The InvokeURL command doesn't work when one or more layers are specified as constraint.
- Version set to new value
1.0.0
- Priority set to new value
P2
- Summary set to new value
- Artifact Status set to new value
New
- Artifact created
- Component set to new value
Web Server Extensions
- Subcomponent set to new value
Viewer Command
- Defect Severity set to new value
High
- Steps to Reproduce set to new value
Add a new InvokeURL command to WebLayout
Select the "Additional Parameters" tab
In the Use only these layers - select any specific layer instead of "All layers"
InvokeURL can't be invoked from DWF and AJAX viewers
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
