[mapguide][MG296][Modified] Define Search Command using Like $USER_VARIABLE doesn't work
Alain Lebatard
alain.lebatard at autodesk.com
Fri May 19 18:49:14 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG296
Type:
Defect
Artifact ID:
MG296 (Define Search Command using Like $USER_VARIABLE doesn't work)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
MG296
Modified
File: trunk/MgDev/Web/src/mapviewerjava/common.jsp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewerjava/common.jsp?view=diff&rev=667&p1=trunk/MgDev/Web/src/mapviewerjava/common.jsp&r1=666&p2=trunk/MgDev/Web/src/mapviewerjava/common.jsp&r2=667
File: trunk/MgDev/Web/src/mapviewerjava/search.jsp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewerjava/search.jsp?view=diff&rev=667&p1=trunk/MgDev/Web/src/mapviewerjava/search.jsp&r1=666&p2=trunk/MgDev/Web/src/mapviewerjava/search.jsp&r2=667
File: trunk/MgDev/Web/src/mapviewerjava/searchprompt.jsp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewerjava/searchprompt.jsp?view=diff&rev=667&p1=trunk/MgDev/Web/src/mapviewerjava/searchprompt.jsp&r1=666&p2=trunk/MgDev/Web/src/mapviewerjava/searchprompt.jsp&r2=667
File: trunk/MgDev/Web/src/mapviewernet/common.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/common.aspx?view=diff&rev=667&p1=trunk/MgDev/Web/src/mapviewernet/common.aspx&r1=666&p2=trunk/MgDev/Web/src/mapviewernet/common.aspx&r2=667
File: trunk/MgDev/Web/src/mapviewernet/search.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/search.aspx?view=diff&rev=667&p1=trunk/MgDev/Web/src/mapviewernet/search.aspx&r1=666&p2=trunk/MgDev/Web/src/mapviewernet/search.aspx&r2=667
File: trunk/MgDev/Web/src/mapviewernet/searchprompt.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/searchprompt.aspx?view=diff&rev=667&p1=trunk/MgDev/Web/src/mapviewernet/searchprompt.aspx&r1=666&p2=trunk/MgDev/Web/src/mapviewernet/searchprompt.aspx&r2=667
File: trunk/MgDev/Web/src/mapviewerphp/common.php https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewerphp/common.php?view=diff&rev=667&p1=trunk/MgDev/Web/src/mapviewerphp/common.php&r1=666&p2=trunk/MgDev/Web/src/mapviewerphp/common.php&r2=667
File: trunk/MgDev/Web/src/mapviewerphp/search.php https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewerphp/search.php?view=diff&rev=667&p1=trunk/MgDev/Web/src/mapviewerphp/search.php&r1=666&p2=trunk/MgDev/Web/src/mapviewerphp/search.php&r2=667
File: trunk/MgDev/Web/src/mapviewerphp/searchprompt.php https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewerphp/searchprompt.php?view=diff&rev=667&p1=trunk/MgDev/Web/src/mapviewerphp/searchprompt.php&r1=666&p2=trunk/MgDev/Web/src/mapviewerphp/searchprompt.php&r2=667
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
