[mapguide][MG296][Modified] Define Search Command using Like $USER_VARIABLE doesn't work
Alain Lebatard alain.lebatard at autodesk.com
Fri May 19 18:50:30 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG296
Type:
Defect
Artifact ID:
MG296 (Define Search Command using Like $USER_VARIABLE doesn't work)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
-- Resolution Description set to new value:
Escape filter expression for embedding in HTML code
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
