[mapguide][MG296][User] Define Search Command using Like $USER_VARIABLE doesn't work
Alain Lebatard
alain.lebatard at autodesk.com
Fri May 19 18:50:39 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG296
Type:
Defect
Artifact ID:
MG296 (Define Search Command using Like $USER_VARIABLE doesn't work)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- New value added to attribute Reviewer:
trevorwekel
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
