[mapguide][MG296][User] Define Search Command using Like $USER_VARIABLE doesn't work
Trevor Wekel trevor.wekel at autodesk.com
Fri May 19 19:25:39 EDT 2006
Hi Alain,
Just out of curiousity, have these defects been approved by Paul and
Bob/Hartesh?
Thanks,
Trevor
-----Original Message-----
Sent: Friday, May 19, 2006 4:51 PM
To: Alain Lebatard; Trevor Wekel
Cc: issues at mapguide.osgeo.org
Subject: [mapguide][MG296][User] Define Search Command using Like
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG296
Type:
Defect
Artifact ID:
MG296 (Define Search Command using Like $USER_VARIABLE doesn't work)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- New value added to attribute Reviewer:
trevorwekel
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
