[mapguide][MG349][Modified] AJAX Viewer does not display multi-line labels
Walt Welton-Lair
walt.welton-lair at autodesk.com
Wed Nov 8 10:46:16 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG349
Type:
Defect
Artifact ID:
MG349 (AJAX Viewer does not display multi-line labels)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Developer Notes set to new value:
Old value:
Fixed a problem with DWF Viewer when rendering rotated multi-line labels. The text rotation was not being correctly account for.
Multi-line simple labels in AJAX Viewer are now rendered correctly, both for regular and tiled maps. Multi-line path labels (the ones which follow a polyline) are not yet supported. The work for the latter will be done in a future MG release.
Any of the following substrings will be interpreted as a line-break:
- "//n"
- "/n/r"
- "/r/n"
- "/n"
- "/r"
Fixed a bug with simple label underlining in which the underline wasn't being rendered antialiased.
Fixed a bug in which rendering of the opaque background wasn't correct in the case of a rotated label.
New value:
- "\\n"
- "\n\r"
- "\r\n"
- "\n"
- "\r"
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
