[mapguide][MG447][New] Non-uniformly scaled symbols don't draw at correct position ...
Walt Welton-Lair
walt.welton-lair at autodesk.com
Wed Nov 8 11:46:07 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG447
Type
Defect
Artifact ID
MG447 (Non-uniformly scaled symbols don't draw at correct position in DWF Viewer)
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Subcomponent set to new value
Core
- Description set to new value
Symbols that have a non uniform scale applied to them are not being rendered at the correct position.
When the symbol aspect ratio is > 1.0 the symbol’s x translation is wrong.
When the symbol aspect ratio is < 1.0 the symbol’s y translation is wrong.
- Platform set to new value
All
- Version set to new value
1.0.2
- Operating system set to new value
All
- Steps to Reproduce set to new value
This is just one way to see the problem.
1/ Create a map with points and some other reference geometry - lines or polygons.
2/ Configure the point style to use a marker symbol with an aspect ratio not equal to one.
3/ Using DWF Viewer, open the map and zoom in to a reasonable level where some symbols are still visible.
4/ Zoom out, without releasing the mouse, and note that the symbols move away from the reference geometry.
- Priority set to new value
P2
- Defect Severity set to new value
Medium
- Component set to new value
Server
- Target milestone set to new value
1.1.0
- Summary set to new value
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
