[mapguide][MG450][Modified] Selection does not work with King Oracle
Haris Kurtagic haris at sl-king.com
Sat Nov 18 05:02:31 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG450
Type:
Defect
Artifact ID:
MG450 (Selection does not work with King Oracle)
Modified by:
Haris Kurtagic
haris (haris at sl-king.com)
The following modifications were made to this artifact:
Added following comment to artifact::
I have tested and selection works for me if feature class has identity. King.Oracle is working on spatial tables without need of additional metadata tables, so it is creating identity on class if table has primary key defined on it.
So if you ty table with primary key it should be selectable.
This design that selection works only for classes with identity is something which is designed in MapGuide.
Difference betwean Autodesk and King provider in your case comes I suspect because you have tested again tables created with Autodesk FDO schema metadata tables.
For example if you try Autodesk provider on foreign schema than item would be selectable in King Oracle ( if table have primary key) provider but not in Autodesk provider.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
