[mapguide][MG454][New] Add ability to turn on/off parts of themed layers
Andrew
andrew.demerchant at gemtec.ca
Mon Nov 20 16:03:28 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG454
Type
Enhancement
Artifact ID
MG454 (Add ability to turn on/off parts of themed layers)
Reported by
Andrew
andrew_demerchant (andrew.demerchant at gemtec.ca)
New artifact details:
- Description set to new value
It would be nice if we could turn off/on themed layers according to their theme. I have a themed layer of several types of monitoring points, so in my "monitoring points" layer, there are 6 different icons. It would be great if I could easily turn on/off any of those icons. As it stands, the only workaround for this would be to make 6 copies of the same layer, and filter each on the type.
- Artifact created
- Justification set to new value
This would save having to make multiple copies of the same layer, and then running multiple filters. Should be faster.
- Artifact Status set to new value
New
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
