[mapguide][MG435][Modified] Undo changes made in artifact MG333
Steve Dang
steve.dang at autodesk.com
Fri Oct 20 19:35:09 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG435
Type:
Task
Artifact ID:
MG435 (Undo changes made in artifact MG333)
Modified by:
Steve Dang
stevedang (steve.dang at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
Modified
File: trunk/MgDev/Common/Schema/DrawingSource-1.0.0.xsd https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Schema/DrawingSource-1.0.0.xsd?view=diff&rev=926&p1=trunk/MgDev/Common/Schema/DrawingSource-1.0.0.xsd&r1=925&p2=trunk/MgDev/Common/Schema/DrawingSource-1.0.0.xsd&r2=926
File: trunk/MgDev/Common/Schema/FeatureSource-1.0.0.xsd https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Schema/FeatureSource-1.0.0.xsd?view=diff&rev=926&p1=trunk/MgDev/Common/Schema/FeatureSource-1.0.0.xsd&r1=925&p2=trunk/MgDev/Common/Schema/FeatureSource-1.0.0.xsd&r2=926
File: trunk/MgDev/Common/Schema/LoadProcedure-1.0.0.xsd https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Schema/LoadProcedure-1.0.0.xsd?view=diff&rev=926&p1=trunk/MgDev/Common/Schema/LoadProcedure-1.0.0.xsd&r1=925&p2=trunk/MgDev/Common/Schema/LoadProcedure-1.0.0.xsd&r2=926
File: trunk/MgDev/Common/Schema/MapDefinition-1.0.0.xsd https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Schema/MapDefinition-1.0.0.xsd?view=diff&rev=926&p1=trunk/MgDev/Common/Schema/MapDefinition-1.0.0.xsd&r1=925&p2=trunk/MgDev/Common/Schema/MapDefinition-1.0.0.xsd&r2=926
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
